Whats my block worth?
OK peeps, I'm after an honest answer as to how much my block is worth.
It is/will be a 4.6 crossbolted block bored to 96mm with top hat liners. Block is being done at the moment, but when I get it back it will be for sale to try and fund a chevy project.
- ihatesissycars
adamnreeves
Re: Whats my block worth?
When you say block, you quite literally bare block? no crank,pistons or rods? Personally I would rather buy block with the crank,rods and pistons, i.e. short engine but that is only because I wouldn't want the hassle of sourcing all the right bits. For this reason I'd want it cheap! I am not in the market but I guess I would be happy to pay £2,500-£3,000 for a short block with forged pistons, rods and crank. Expecting to pay £1,500 for these additional items I guess I would therefore be happy to pay £1,000-£1,500 for the bare block. I would expect to have all the invoices for the engineering work and have a report showing the block as being pressure tested, etc. Phew!
mwncidur wrote:OK peeps, I'm after an honest answer as to how much my block is worth.
seight
The thing is, with it bored to 96mm everything else is going to be expensive/custom to make a big capacity engine. So maybe someone in the market for that would be prepared to pay a premium.
However - a bare used (maybe even bad) 4.6 block would only be a couple of hundred then add on the cost of top hat liners (to cure a leak?) at £600ish and your looking at £800 tops IMO
I think it will be worth a grand of any ones money. As for saying that a 96mm block is going to be expensive is wrong ! I have gone the 96mm route and it is no more expensive than sticking with the 94mm block. Its only the pistons that are diffrent and they are all the same price 94mm or 96mm, and if you are buying new like you would if you were building a new engine then they are readily avaliable. Dont take any less that £1000..
Was Rover v8 10.7@122mph, 0-60-3.01sec
Now Blown BigBlock Chevy 9.9@134 upto now on low boost.
- ihatesissycars
It depends of your strokeihatesissycars wrote:Where did you get 96mm pistons for the same cost as standard 94mm jobbies?
With 86mm stroke you can use flat top Chevy 305 + 0.04'' (95.9104mm) pistons who are avaiable in hypereutectic or forged from KB-Silvolite.
An set of hypereutectic costs around 120USD on Ebay.
I got my whole bottom end from wildcat engineering. He is never in a rush to get anything done but i think his prices are good.ihatesissycars wrote:Where did you get 96mm pistons for the same cost as standard 94mm jobbies?
Boosted LS1
- Knows His Stuff
This is what I am hoping to do what length of rods did you use 5.7 or 6".Wotland wrote:It depends of your strokeihatesissycars wrote:Where did you get 96mm pistons for the same cost as standard 94mm jobbies?.
Can you stroke a 82mm 4.6 crank to 86mm?.
