Not Starting?
dicky
Not Starting?
Post by dicky »
I have a 1992 Range Rover 3.9 V8 Classic.
The other day I noticed that when I came upto junctions the engine kept cutting out. To add to that it is very hesitent when starting from cold.
This morning however i turn the igntion on and the '!' engine light is on and then won't start.
I can hear the pump wuring away and fuel moving throught the rail and I checked the King lead and there is a nice big blue spark.
To add i recently changed the coolant temp sensor.
Any ideas?
1992 Range Rover 3.9 V8.
Sounds like reading the fault code would be the best place to start.
dicky
Post by dicky »
Would I be right in thinking I would need an OBD1 code reader or is there another way? It is the pre-cat version ECU.
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Not sure a 1992 Rangie has that facility.
dicky
Post by dicky »
Rossco wrote:Not sure a 1992 Rangie has that facility.
I see, what would I need to read the ECU fault codes then?
Any specific bit of kit you can recomend?
scotb
Post by scotb »
dicky
Post by dicky »
I don't think that will do it, the ECU light remains on when the igntion is switched on before I even crank it.
I can hear the fuel pump pumping but it doesn't seem to stop.
What conditions cause the ECU light to show before cranking?
Does it get a signal from the fuel pump off the relay at all?
