which one to go for ?
intermotor 50611 3-5 psi
or
intermotor 50600 5.8-10psi
oil pressure switch
Re: oil pressure switch
Quite apt as mines gone toobodger wrote:which one to go for ?
or
looks like in depends on how old the engine is :
http://partfinder.smpeurope.com/index.h ... alue=13421
http://partfinder.smpeurope.com/index.h ... alue=27500
mine started off life as a 90/110 landie lump so i'm going for the 50600
My oil light has stopped working too
is there any way to check the bulb and wiring is OK before replacing the oil switch as it isn't very old and I would be surprised if it had failed again, no light when ignition is on but im sure the light flickered for a nano second whilst the starter was cranked. Any ideas?
Mk3 Toyota Hilux 4x4 with 3.9efi RV8 now with Marlin Crawler Transmission
take the connector off the pressure switch and put it to earth ..if the bulb lights it the switch ..
because thats all the switch does ..when no oil pressure the switch just puts the wire to earth so the bulb lights and when you have pressure it breaks the connection ..light off
