rover starter
if its only done it since the gearbox has been fitted i would start looking as previously mentioned, at starter to ring gear mesh and shimming of the starter.
or check the ring gear full stop.
Is the throw out and cogs greased?
It could be that being new it is not moving freely and could do with assistance
When Bone's starter played up at the RR day, I turned the engine by hand several times to make sure the ring gear had moved to 3 or 4 different positions and it still just clicked without engaging.
After the new earth leads were fitted it seemed to settle down for a while. Then it started clicking again as if the as if the drive cog was not engaging far engough to allow the solenoid to put power to the starter motor.
Certainly sounds like its not engaging far enough to me..
Rich
If you need a Rover V8 flex plate. I have a spare one with brand new ring gear if you need it.
Yours for the price of postage. Or get it from me at the Pod on 11th / 12th October.
Perry
Perry
Thanks for the offer Perry, well my day started at 7 am, in the garage making a spacer, starter out 1st time fitted the plate, starter back in, the usual click, starter out for 2nd time to put some washers on and try that, starter back in and again the click. i get under the car and my bro turns the key and i can see the cog engaging, So know we look at the wiring, test it changed it, and still just a click, i follow the wires from the starter and one goes to the fuse box and guess what i found the problem after all this bloody time . A FUSE WAS,NT IN CORRECTLY, once i put it in right ,tried the car and it started and 25 attempts later its still starting, so took starter out took off the washers and plate ,starter back in and its still starting, ive gone through 3 starters 2 batterys and it was a poxy fuse, thanks for the replies all,
Rich
Doh!
glad you sorted it mate,
want to come and sort mine out now?
as its got me beat at the mo
