Air leak found !
JSF55
Air leak found !
Post by JSF55 »
I've been chasing around trying to find what was causing the idle to be so high on my Megasquirted pop, i've just found another air leak, missed the 2 screws for the heater plate under the plenum :( then i found i've missed the little stub that pokes out from under the air idle valve on the hotwire plenum :( does anything connect to this? i thought it was an alignment dowel :lol:
So thats where it went !
Paul B
Re: Air leak found !
Post by Paul B »
JSF55 wrote:I've been chasing around trying to find what was causing the idle to be so high on my Megasquirted pop, i've just found another air leak, missed the 2 screws for the heater plate under the plenum :( then i found i've missed the little stub that pokes out from under the air idle valve on the hotwire plenum :( does anything connect to this? i thought it was an alignment dowel :lol:
Told you it was an air leak mate :D
You get home from Billing okay?
Not sure if I told you when I saw you, but I bought a stainless steering column and a shiny metalflake silver steering wheel for the Jago. Mmm, sexy 8-)
JSF55
Post by JSF55 »
LOL, yep you we're right, just taken me an age to find this on, shiney stuff? make a change from the old morris then !
JSF55
Post by JSF55 »
AH ! much browsing of the internet shows me it's the take off for the fuel pressure regulator vacuum signal, no wonder it was leaking, a quick replumb and a straight feed to the MS, sees a nice idle at 700 rpm ..... result ! john
