Air leak found !
Air leak found !
I've been chasing around trying to find what was causing the idle to be so high on my Megasquirted pop, i've just found another air leak, missed the 2 screws for the heater plate under the plenum
then i found i've missed the little stub that pokes out from under the air idle valve on the hotwire plenum
does anything connect to this? i thought it was an alignment dowel
So thats where it went !
Re: Air leak found !
Told you it was an air leak mateJSF55 wrote:I've been chasing around trying to find what was causing the idle to be so high on my Megasquirted pop, i've just found another air leak, missed the 2 screws for the heater plate under the plenumthen i found i've missed the little stub that pokes out from under the air idle valve on the hotwire plenum
You get home from Billing okay?
Not sure if I told you when I saw you, but I bought a stainless steering column and a shiny metalflake silver steering wheel for the Jago. Mmm, sexy
