Any ideas? bent push rods
i still have a couple spare here that you sent me mike if he needs one mate,
Paul,
are both the reliefs the same size? or is the exhaust one smaller?
and has the valve touched the piston crown and not in the relief?
Paul V8
Post by Paul V8 »
Er, i think so. And some instuctions on what to do with it please.
Nick Moore
Post by Nick Moore »
Can you post some pictures showing where the valve marks are in the pistons?
It may be possible to alter the valve cutouts (which you've no doubt already figured). Good luck!
It's not a bodge if no one finds out!
sidecar
Post by sidecar »
kiwicar wrote:sorry all I was wrong!
So was I, as usual!
Paul V8
Post by Paul V8 »
The timing gear i am using is the Edelbrock Timing Set TRUE Duplex Roller Chain, as supplied by V8 tuner. The valve timing is correct, the more i look the more it looks like a clearence issue, has any body got some pictures of piston pockets, how deep can i go?? Could i use a solid lifter to mock up the engine and check?? Does anyone have an old solid lifter? Thanks. :(
Piston cutter made from one of Mikes chevy valves :wink:
The reliefs i cut using the above cutter, i think i went to 3mm depth when i cut mine,
sidecar
Post by sidecar »
Paul V8 wrote: Does anyone have an old solid lifter? Thanks. :(
You may have missed the comment in my rather long post, you can make a solid lifter out of an old hydaulic lifter by taking it apart and filling it with candle wax! You need to refit the inner cup so that it can not be compressed at all once the wax has set and also so that it is tight up against the retaining spring. I'd also use weak tester springs.
You can then get the piston about 10mm before TDC with the valves on the rock and then push the valves down by hand to see if they hit anything, move the piston up a couple of mm then test the valves again. Keep repeating the process until about 10mm ADTC
I have a load of old lifters that you can have if you want them plus some pushrods that are in good nick.
Pete
im using the crower 50233 cam which is the next one up from yours and has more lift, with the above cutter my valves dont hit, and i use stg 3 heads with larger valves,
