A great quote in DV's A-series book I think it was, and perhaps others regarding camshafts.
Pick the camshaft you want, then buy the next stage/level down from it.
I remember reading about these many years ago (are they even available now?), seems to me they give something like the Honda VTEC effect in that they will alter the cam duration and, presumably, at low RPM then full cam defined duration and lift at higher RPM (something like 3000?).stevieturbo wrote: ↑Wed Nov 05, 2025 9:12 pm Rhoads lifters are designed to bleed down. And this would be more so at lower rpm, when there is force over a longer time to eject oil and effectively reduce lift/duration seen at the valve.
Well I wouldn't say the behaviour is crap, probably more like sub-optimal. Anything less than about 1200RPM does not pull smoothly, I know that sounds like very low RPM but it would work very well in my car when at slower speeds which are a fact of life.stevieturbo wrote: ↑Wed Nov 05, 2025 9:12 pm I have used some of the Real steel cams years ago, and certainly don't recall them being crap low down, but it's sooooo long ago not really sure. And my RV8 in various guises was always twin turbo, never n/a
I think I always used the Rhoads lifters too, tickety tick.
GDCobra wrote: ↑Tue Nov 04, 2025 1:12 pm One other thing I did wonder about is whether there is any lost motion with a hydraulic lifter. I've never had one of these apart but I'm guessing they have some sort of port in them to let oil in which will close off as the lifter rises (similar to a brake/clutch master cylinder) this could result in the base of the lifter rising somewhat before motion is transferred to the pushrod. Perhaps during early motion when valve spring is not applying too much force the oil pressure is enough to prevent relative motion - Any body know more?
It could just be a tuning issue ?GDCobra wrote: ↑Thu Nov 06, 2025 10:31 am
I also think this is possibly why (or at least contributing to) my excessive timing requirement at low RPM)
Were the Rhodes really tickety?
stevieturbo wrote: ↑Thu Nov 06, 2025 6:27 pm It could just be a tuning issue ?
The Rhoads were ticky, but no real annoyance really. As to how much they really changed things, no idea, as don't think I ever ran them against standard type lifters to compare.
No.FBW wrote: ↑Fri Nov 07, 2025 1:32 pm That's what I would have expected.
Theoretically, a larger valve overlap should only make sense on a turbocharged direct-injection engine. It would improve scavenging without heating the exhaust.
Interesting! I'd never thought about that before (due to my problem).![]()
