The primary side is fairly obvious - current flows between +12v and ground, when it is 'turned' on.
But there is no continuity between plug outputs to ground, so I've sort of assuming current is induced into the secondary winding which then flows from one plug to the other on the same circuit? Measuring between both plug outputs on one coil shows a resistance of approx 12,000 ohms. Can't really get my head round current flowing between two grounds.
