tuning hotwire system
markmills2000uk
so far the knowledge i have is
throttle potentimeter thing
Red from volt meter to red wire of pot. Black wire from volt meter to Green of pot and get to between 0.34 and 0.35 so i put it to 0.34 volts
next is the air flow meter which for a non cat system like mine is using multimeter on Red with Black trace and Blue with Red trace wires get to between 1.0 and 1.5 volts
so next i need to do the allan screw bit thats by the throttle on the plenum,does anybody know how to do this
is there anything else i need to do,
cheers guys,
cheers guys,
Warm up the motor to normal running temp.
Remove the rubber hose that feeds the stepper motor and blank off both of the stubs it was fitted to.
Adjust the base idle to 525 rpm on a good tacho with the allan screw by the throttle plate.
Remove blanking plugs and restore rubber hose.
The adjustment of the AFM may well require altering as this should be set to give correct emmissions for the MOT test.
The above adjustments may well be interdependent.
jw
jw
Since engines typically aren't at all keen to idle at 500 rpm, I find it's easier just to squash that bypass hose flat by pressing it against the throttle assembly, when adjusting the base idle. If the engine seems to be in danger of stalling, just release the hose for a moment until the revs have recovered.jwriyadh wrote:Warm up the motor to normal running temp.
jw
Peter Humphries (and a green V8S)
markmills2000uk
im unable to do it as the engine is running quite badly at the mo,i cant figure it out,with everything connected it wont start if i take the vacuum hose off the fuel pressure regulater it will start it i put my finger over the pipe that comes out the plenum which is now open it stalls,any ideas,
car also seems to be running quite rich,floods really easily
are you saying when you block the pipe the engine stalls?
If so unscrew the air screw by the throttle a little with everything put back together and see if that helps. It could be that this air bypass is gumed up (or even badly adjusted) so if it doesnt help I would maybe look at cleaning this out. I am not sure if the stepper motor is capable of supplying enough air for the engine to idle on its own.
markmills2000uk
ok that problem just went away but its still not running right,i tried adjusting that screw and it doesnt reall do much to the engine running so as im not sure why its not running right,im going to put another hotwire plenum on and start again and go from there,
no doubt il be back on tommorrow asking more questions,
i thought it was just going to be easy connect it all up and it work,theres always something,im slowly getting there though
markmills2000uk
markmills2000uk
markmills2000uk
