Bosch 044 Fuel Pump, Check valve or not
leylandracer
Post by leylandracer »
Should i be using a check valve on a Bosch 044 Fuel Pump? Ime just on with putting the upgraded pump on, The old (Standard) Sytec pump didnt have one fitted, Ime using a 8mm barb fitting, Just a bit puzled :?:
Thanks, Steve
I dont use one, mainly because my pump didn't come with one originally.
Just means your rail dosn't remain pressurised when off.
There is absolutely no need for a check valve.
leylandracer
Thanks...
i was not running one, but now i am
only difference i have found hot starting is a lot easier now.
Coops the PIKEY wrote:i was not running one, but now i am
Yes - there's a factory fit hot start mod on my SD1. Basically, above a certain radiator temperature, it shuts off a valve fitted to the fuel rail return, and bypasses the inline resistor. So the pump runs up to maximum pressure, while cranking.
SimpleSimon
Post by SimpleSimon »
Thats an added bonus then, said valve was essential on the old Bosch K/KE Jetronic systems to stop fuel percolation :D a left over device I feel from that system.
