charging
charging
Hi folks.
just fitted a new battery, new alternator was fitted early this year. when the engine is idling voltmeter sits at 12v and doesnt move when engine is reved up. the engine is a rover 3.5 fitted into a mk2 hilux, any body have any ideas whats up?
Is that a dash voltmeter? If so, check with a DVM across the battery. Should read 13.8 volt at a fast idle with a fully charged battery and no load other than the engine electrics.
The dash voltmeter may give an incorrect reading due to many things.
Re: charging
Again, is this a dash meter? If so, it could be a problem with that or its wiring rather than the battery/charging circuit. Indeed, I'd say that is more likely.shawser wrote:funny thing is before my old battery died, the voltmeter sometimes would show nothing, then it would jump to 14v, then nothing again.
I've fitted a voltmeter to my SD1 - it had only a warning light. It's in the revcounter, and at first I wired it to the rev counter supply. The readings it gave were nonsense. So it is now wired direct to the battery via an ignition controlled relay.
Re: charging
That would depend on how accurate the voltmeter is and if it's working correctly.shawser wrote:so if i take it off and connect it straight to the battery , if all is well then it should idle around the 12v mark and go up to around 13.8 when revving?
A fully charged battery will read just over 12 volts with the engine stopped.
At idle (with most alternators) and only the engine electrics on, I'd expect to see 13.8. Roughly.
A DVM is a good investment if doing any electrical work. They are remarkably cheap these days. A few years ago to get that sort of accuracy would have cost a lot of money.
Re: charging
Would be best.shawser wrote:i took off dash volt meter and connected to battery, reads just over twelve with engine off, the same on idle. looks like i need to get a proper volt meter.
Did the new alternator come from a reputable source? Many cheap 'reconditioned' ones are simply cleaned up used from a scrappie.
Re: charging
Ah. If that's not connected, no charge. Same as if the bulb blows. It needs a tiny amount of current from the battery to start it charging, and it gets that via the warning light.shawser wrote:it was a brand new one from a rover dealer. trying to sus out where the thin wire goes to for charge light. see if light goes out.
