Rover water pump pully size?
Jono FD3
Hi guys, couls someone tell me the diamiter of the waterpump pully on the rover lumps (not the serpentine type)
I'm having a bit of bother finding one, and the new ones are about £50 so I had a thought of spinning up an aloy one on the lathe as the material can be had for sencible money!
Jono
Jono
Re: Rover water pump pully size?
My alloy one is 175mm diameter. It's fitted to a p5/p6 type pump.Jono FD3 wrote:Hi guys, couls someone tell me the diamiter of the waterpump pully on the rover lumps (not the serpentine type)
Jono
Cheers Denis
It rather depends on the water pump you're using. There are two listed for the SD1 - one NLA, the other about 25 quid from Rimmer. I'd guess Landie ones are cheaper.Jono FD3 wrote:Hi guys, couls someone tell me the diamiter of the waterpump pully on the rover lumps (not the serpentine type)
Jono
pictures are a problem, as I am in the process of moving house, everything useful is packed like my camera, and other helpful things, but if you pm me your mobile number I may be able to send you one
