The number is
35509437B
It would appear to be (and probably is) a Range Rover engine but the letter code is unusual. It is absolutely clear and is not over stamped. It also has a 8.5:1 Compression ratio which is also odd. At the moment I haven't taken the engine in bits as it is supposed to be "good to go" but I guess if I want to know what it is exactly then I will have no choice.
