the full build and my race results are on my web sight
www.johnnycichowski.com
Not bad! Rpm, oil temp, water temp, oil pressure, and fuel gauge. only what i need. I'll need to do something about the wheel. I'm thinking Nardi.....
Building race cars = a big mess.
see my championship winning 1.6l miata in the background. (with white wheels)
Diff came in!! I went with a factory replacement. with the small wheels I'll be running this should have no issues locking up.
I cheated and went the easy way out with a new harness
before
After!
Seam welded. You can really fell the transitions allot better without all that glue holding the car together.
Another example of my crap welding.
BIG stoppers for my little car
stance is a local company so if i need to change spring rates or valving i can just stop on buy. i actualy went to a 10k 8k spring rate after my first track event.
more pics of my mess
my tiny wheels next to my wife's wheels. she has the red 350z
they don't make big tires for 15" wheels so i had to go super sticky tiny wheels.
prep for paint
got the motor in there
new 1/2 cage
new sub frame
got it swapped. took me about 20 min to swap everything
