Rover 3.5 oil filler neck...
Sorry for all the questions guys!! LOL
Does anyone know if the short extention tube for the oil fill unscrews fro the rocker box or is it part of the casting?? Reason being I would like to remove it and have it like the later p38 rockers with an after market flush oil cap as I'm going to doctor them a little to improve the looks of the engine!
Jono
Jono
Re: Rover 3.5 oil filler neck...
Yes. IIRC, it has the same thread as the opposite side on some versions which takes the flame trap.Jono FD3 wrote:Sorry for all the questions guys!! LOL
Jono
Jono,
You can use the original oil cap and smarten it up by removing the plastic cover and polishing it, but you must grind off the area below the thread otherwise it will make contact with the rockers with resultant expensive damage.
you can get modified ones off e-bay but it's easy to do yourself.
Kevin
Kevin
Sorry to necro-post, but makes more sense than creating a new one.
Anybody any insightful tips for removing the oil filler neck? I'm having a mare, it's having absolutely none of it.
_________________
1994 Rover 820 Vitesse fastback
1995 Land Rover Discovery 3.9 V8 manual
2004 Vauxhall Astra 1.7 CDTi SXi
Vard.
Vard.
- ged
I've found gripping the neck in a vice & turning the cover works. If you're still struggling try tightening it slightly first before undoing it as this will help break the crud seal.
I do make filler caps & also filler necks so if you would like one of these pm me. I'll remove the part before the thread at no extra cost.
Best Regards
Ged
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_949
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _678wt_932
Best Regards
Ged
