draining water from RV8 block
martin_t
Post by martin_t »
I need to take the heads off my Rover V8 and wondered if anyone could tell me if I can drain enough water out of the heads\block by just removing the bottom hose (I guess the lowest hose is from the water pump) and draining. the tap\plugs on either side of the block are a sod to get to on my Cobra Replica and I thought If I didn't need to take those out, I wouldn't.
Last time I did it, I just drained the radiator but when I removed the heads there was still a lot of water in there which went everywhere.
Martin
If you undo both the top and bottom hose and blow down the top hose it normally gets enough water out to seperate the heads without too much mess.
I always drain the block to be sure.
bodger
Post by bodger »
is there still the small bolt/plug on each side of the block , about central along each side below the head split line ?
there is on mine and i have seen some engines with a sort of TAP there too :)
DEVONMAN
Post by DEVONMAN »
If you can jack up the back of the car up as high as possible after you removed the bottom hose then you should be fine.
The problem usually is water trapped at the back of the engine due to the engine angle and jacking will allow it to flow to the front.
Cheers Denis
Return to “Cooling Area”
