Hi guys, I'm about to rebuild a rover 3.5 but I need to get an intake system sorted.... basicaly the engine has a crane 286 cam and I'm going to be porting the heads to improve flow, tubular manifolds and a single 3" single box exhaust system...... now to feed it I was looking at getting the twin SU setup, but the guy I got the engine from sujested a holley setup as this should give the engine around 200bhp, but looking at the prices I was wondering if it would be more cost effective to run it on bike carbs with a custom intake manifold(s) (making the manifolds isn't a problem as I would make them out of stainless steel tube)
has anyone done this before, and what carbs would you recomend?
Jono
rover 3.5 on bike carbs?
It has been done, however the carbs are not designed to work at there best in the capacity/rev range that the 3,5 rover operates at. This makes them hard to set up and get stable, it can be done but it is not easy.
Why not use the SUs? They can easily handle 200 bhp as is, they are good for 230, and with a few basic tweeks you can get them to fuel 250 bhp. They are much easier to set up and someone will be able to find you a needle that is in the ball park for the tuning you are intending.
Best regrads
Best regrads
