What is a low tension lead that plugs into amplifier module
roverv8tom
Post by roverv8tom »
What is a low tension lead that plugs into amplifier module on dizzy
what is it and where do you connect coil?
why do v8 engiines send chills up your spine
White wire goes to coil +ve and ignition feed
White / black goes to coil -ve
sidecar
Post by sidecar »
Just to add to what Chris posted you should also have a 12 volt feed going to the coil from the wiring harness. There may well be another lead coming off the negative of the coil, if there is one it will possibly be going to the rev counter. (Not to earth!)
