The Crank came out of my last block, 120K miles, and has only had a light polish. Still standard size, and right in the middle of the specs.
At first I thought the reason for it jamming was the crappy main bearings I was supplied with my block (had to be gently hammered onto the centre-main & wouldn't sit neatly on the tang groove) so I bought some OE bearings.
The clearance is up around .0015" when I torque and measure each individual journal... A little tight - but probably OK I feel.
I don't believe the crank is bent because when I torque each of the mains up to 20Nm, it spins, a little tight, but cleanly spins without a tight spot or anything else that I suspect would happen with a bent crank (not that I've ever had one though)...
I can fully torque journals 1 3 and 5 and have it spin, but when 2 and 4 are torqued - these are locking it up. Conversely, torquing 2 and 4 and leaving the others loose and it also spins.
I'm going to take the block and crank to the machine shop on Monday to have it checked, and line honed if needed.
I'm just curious if it is common for these engines to need line-boring. I honestly don't know the history of the engine block, nor the main caps as I paid the surcharge for them to supply me a block. I was just hoping (assuming) that this would have been checked by the guys at V8D - I'm nowpretty confident this isn't the case however, given that they even forgot details like running a tap down the holes, cleaning the swarf out of the rear cam plug, honing the block to an acceptable surface finish, and stamping the block with the numbers to match the paperwork...
I do still have my old engine block - I'm tempted to stick the new shells and crank in there to see if it's the same, as I know this setup worked together at least. I guess that'll help point to the crank or the block as being bad...
Any advice opinions or insults welcome!
