Hi all, i just been offered a v3 megasquirt ecu that has never been used.... it was brought for a zetec 4 pot but the guy couldnt get it to run??. he says it must have been a 'software'problem??,, how easy would it be to 'reprogram' this to be able to run my rv8???
where can i get it tested..... or should i leave it alone? (its £150 with leads and a old laptop thats suitable this ecu?) Thanks in advance Steve
megasquirt
V3 refers to the PCB which is the latest one using discrete components. The processor could be either an MS 1 or MS 2. The MS 1 is a single chip - the MS2 a daughter board which fits the same slot.
To re-program for a different engine you simply load in an MSQ file that's suitable - or you can start from scratch. I'm sure someone here will give you one that would be a decent starting point - if you give the full spec of your engine and ignition and the MS.
Pretty well any PC Win95 or later will run the software. (and Macs - but dunno them) It needs a serial port or a USB to serial adaptor. Many have problems with this adaptor rather than with the MS itself, when they can't establish communication.
It's well worth while getting a Stim. This simulates the ignition tach signal and all the sensors. Using either a battery or a wall wart PS, you can then establish the MS is working properly off the car, and check your computer is talking to it ok, etc.
Most problems are caused by a faulty engine loom. Wrong grounding of sensors, etc. The MS itself is pretty reliable - and easily fixed if the worst happens by anyone with some electronic knowledge. Being a DIY device, it has no special chips etc that you can only get from the vendor - they are all 'stock' devices.
Re: megasquirt
I would send Phil Ringwood a PM he is daxtojeiro on heremgrv8 wrote:Hi all, i just been offered a v3 megasquirt ecu that has never been used.... it was brought for a zetec 4 pot but the guy couldnt get it to run??. he says it must have been a 'software'problem??,, how easy would it be to 'reprogram' this to be able to run my rv8???
or E-mail him. Have a look here He will put you straight as you will probably need some mods to make it right for your RV8.
Jeff
