If all goes well this year I hope to make a good attempt at 9 seconds at the Pod
Sort of new PB I guess??
I Took the MG out a week or so back and did some test runs on the blower. At 7 psi of boost with gentle pedal off the line she made an 11.9 pass with poop mph. My old nasp pb was 13.6 so I'm quite happy with this right now. The blower can make 16 psi if required so I might try to spool this up a bit more..
kev_the_mole
kev_the_mole wrote:Got your parachute?
Yes mate!! And spare undercrackers
kev_the_mole
I spent some time at the Pod today tweaking ign timing and got it down to 11.7's still running the 7psi of boost. 60 foots were ok at 1.7 and 1.8 seconds. But I need more power off the line now.
While I'm waiting for new blower pulleys to arrive to give me more boost I thought i'd go and play at Noth weald yesterday.
I had to smoke the slicks up real hard to get some grip. But traction was an issue for everyone on the concrete. I stuck a 100 shot on top of the blower and made the good mph again. But ET's were not so good. At least it shows I have some extra push for the last half of the track. The best run of the day was 11.0 @ 126.5 mph. And I left 200 feet of black lines behind me when the light went green
I reckon this setup would give me a 10.5 at the Pod so i could get back to where i was in 2009 before all the engine trauma ??
I sort of want to leave it as is for the Retro Show but the new pulleys will be with me on Friday and my dyno man says i can pop over at 10am Saturday to spend the day on the rollers doing some testing. All i need to do now is e jet the carb and I'm good to go.
If she survives the dyno with 1 bar of boost I'll be happy
And I will have a base tune to work from for the Retro weekend when I'll no doubt be chucking some gas in on top
BMWE36V8 wrote:Hi, it was good to see the beast going well at the pod on saturday, did you manage another run after the last time I saw you, did you manage a high 10..???![]()
Steve.
High Steve!
I enjoyed our natter. I did come back to the fire up lane at 5.40pm but they had closed the gate ??
