Camshaft break in ?
Camshaft break in ?
Hi Guys, finally getting the engine back together, installed and timed the cam today and read at the bottom of the instructon page .... vary the engine speed between 1500-2500 rpm for the first 30 minute ... no problem there, but i thought those zf boxes didn't like being reved whilst in park or neutral, any ideas? john
So thats where it went !
The fault with the box is fine if you do the test from a cold box, without having put the box in drive first.
The problem is that when going from D to P or N, it doesn't 100% release the A clutch, and so it burns out. But if you've not put it in D, it won't have selected the clutch so it should be fully cleared.
I think later boxes were fixed in this regard anyway.
You could always do the test in gear on axle stands if paranoid!
No this is the best thing to do, this way you ensure there is a good oil supply to it from the start, and lots of oil splash. The worst thing to do is to sit it at 650 revs with very little oil being pumped around and very little oil splash or oil droplets around the cam. Most cam dammage is done in the first 30 seconds of starting. coat the thing in lots of sticky cam lube to get you over cranking and start up quickly, then get the thing to 2500 as quick as possable.
Best of luck
Best of luck
- HairbearTE
- Guru
No problem with the ring break in it's an old engine !! it'll have to do as i save my pennies for something a bit lager ! john
edit:- lager !! jes i'v had a long day
i'll be breaking my cam in. in the next few days hopefully,
Well that didn't go to plan !! after checking everything i couldn't get no oil pressure had to repack the pump and prime it, then i timed it out by one tooth !!! finally got it running at 2000 rpm no problem but theres a nasty ticking sound coming from the rocker cover area, sounds like one of the lifters hasn't filled with oil ! i'll pull the rocker in the morning and have a listen...... anyone know if these rhodes lifters give a problem ? john
- HairbearTE
- Guru
