Engine swap is nearing completion. I had a 3.5 (knackered) and am going to a 3.9 from a Range Rover (it was on EFI, but I'm keeping it on carbs till the new cam is run in and then going to megasquirt).
I had to keep the new distributor as the oil pump drives were different. The old engine had a lumenition(?) ignition system. This new distributor has an amp on the side.
Can anyone advise what I need to do to get this wired up right?
I've seen the posts by Ramon such as at http://www.v8forum.co.uk/forum/viewtopi ... r+positive but I don't have the old connectors for whatever went on the new distributor amp so I'm kinda stuck a bit.
The old system is here:
New distributor is this type:
So, I'll be junking the amp in picture one (on the bulkhead) and running two wires from the coil to the module on the new distributor?
What's the wiring for the spade terminals on the new distributor? I believe coil+ to one and coil- to the other - but which is which?
Thanks for any help.
A
