Rebuild/service kits for SU HD8 carbs, and rejetting?
chodjinn
Post by chodjinn »
Hey, I was wondering if anyone knew a good (cheap!) place to get a couple of service kits for some SU HD8 (I think) carbs?
Secondly, I'm looking at fitting either a 3.5 or 3.9 with the carbs. They have previosuly been used on both but jetted for 3.5 as far as I know, so how hard is it / what needs doing to rejet them to suit a 3.9?
And finally, anyone know a good place to get them set up once rebuilt, I'm in the NW.
Thanks!
minorv8
Post by minorv8 »
Burlen Fuel Systems (good but not the cheapest)
Rejetting: only needles should need changing.
chodjinn
Post by chodjinn »
I know of Burlen but they are really expensive and the website isn't the easiest to use, I can't find service kits only rebuild kits. Are service kits really around £43 each?! (that's the best I oculd find using google for ten mins).
You might be able to get a refurb kit from a Jaguar specialist. I got mine from Burlen, and didn't worry about the cost.
I used Pete Baldwin to rolling road mine, but he's near Cambridge. He does know his stuff though.
chodjinn wrote:I know of Burlen but they are really expensive and the website isn't the easiest to use, I can't find service kits only rebuild kits. Are service kits really around £43 each?! (that's the best I oculd find using google for ten mins).
There's nothing to service on an SU, IMHO, you just repair what's needed, after a good clean.
I don't think their prices too bad considering the quantities they re-manufacture. Different if they were made by the million.
topcatcustom
Post by topcatcustom »
A gasket or 2, "O" ring on some models and float valve, I've done some but tbh I only bothered changing the valves because I had new ones- they always look perfect!
As Dave said a good clean will do 90% of the job.
TC
chodjinn
Post by chodjinn »
Thanks for the advice guys. Unfortunately something has come up with my other motor that is more pressing so this'll be on hold for a month or two. Will give them a good clean with carb cleaner since I'm skint and see how I fair with that!
thanks as always!
minorv8
Post by minorv8 »
I have a Burlen catalogue somewhere. Do you have the alloy tags with carb ID code attached to the carbs ? I could scan you the relevant pages with part numbers.
