What do you guys think is the min dia i can get away with for my iac plumbing?
4.6 rover v8 using a Bosch valve.
Hoping to use a spare inlet on the plenum base, its about 8mm id! Would that flow enough for cold idle?
min diameter for idle air valve pipe?
