I have recently rebuilt a 3.9 litre engine for my SD1 as follows:
- Balanced the crankshaft with con rods, pistons, crank pulley and (lightened) flywheel
- New piston rings
- RPi Engineering Stage 3 Heads
- Piper 285 camshaft
- Weber/Edelbrock 500 carb
I have done about 1200 miles with this setup now. A few days ago, after a 150-ish mile ride on a german Autobahn (I was going at a constant 75 mph - honestly!), the engine started backfiring and didn't pull as it should. I stopped immediatly and my brother towed me home. First guess was a problem with the ignition system, but after carrying out a compression test, we found out that cylinders 5 and 8 have no compression left at all. Additionally, there's a rattling sound coming from the engine. I guess it's the piston rings, because the valves open and close alright. My guess is that the machine shop where I had the engine rebuilt and honed should have used oversize pistons but didn't, somehow causing the piston rings to break.
As I have to rip the engine apart again
- Can I use any pistons on it, e.g. oversize pistons my machine shop will supply?
- Can I re-use my OEM 3.9 con rods?
- Is it possible that parts from the broken piston rings are causing the rattling sounds I mentioned earlier? If that is the case, can they have caused some more damage inside the engine?
Regards,
Fritz
