Anybody know where i can get a filter that sits inside this flame trap ?
Regards,
Martyn......
It was just such a tight bundle of chicken wire type material that I found in my Vitesse.mgbv8 wrote:I can see chicken wire working just fine if its crushed up enough to reduce the passage ways to create a real maze for the gas to work its way through.
If you've ever tried clearing one off the car with a blowlamp, the wire does burn.kiwicar wrote:Hi
Please don't use wire wool it is too fine to do the job. As a flame retardent medium it needs to have enough mass in each strand to take the heat out of the flame front if it starts, wire wool will burn if you light it. Also being so fine it can get drawn into the engine via the vacuum port, and that is not good for the engine. Use a stainless steel panscrub they are much heavier grade. Or Chicken wire, but I think you will have fun making it into a nice dence bundle.
I have to say I wouldn't have thought of that but I might have to give the Chicken Wire a try!ramon alban wrote:My short answer is - Try Chicken Wire - Confused??Here's Why!
In 1993, when I first looked inside my (then) 7 year old Vitesse flame trap, it contained a very neat bundle of "chicken wire" that I took to be original.
It was VERY crusty with carbon deposits - never been cleaned in that time by PO's, I reckon, and nearly blocked, so it was clearly effective.
I cleaned it off in chemical solution, back to bright metal, and simply stuck it back in the housing. Bienniel cleaning since then and its still OK, 24 years old now.
My understanding is this! The open nature of the item catches and condenses out all the oil which drips back into the engine and the noxious gasses are simply allowed through to be recycled.
Many times since, when-ever the subject is discussed, it's always bothered me that using a wire-wool type replacement would have two detremental effects.
1 the passage of recycled gasses is somewhat restricted.
2 the wire wool type replacement would block up more readily.
Bearing in mind the propensity for neglect hereabouts, that would quickly lead to a blocked breather and poor performance.
So, Chicken Wire seems like a better solution, to me, although I am also taken by the S/S pan scrubber idea providing they are not too close weave.
