kiwicar wrote:Hi Stevie
I should get about 470 ft lb torque out of the engine, if I run it on methanol as a couple of people are adviseing I could be looking at be looking at 580+. If the torque converter gives me a torque multiplication of 2:1, first gear is 2.03:1 and a 4.11 crownwheel and pinion I think I am looking at 9678 ft lb of torque into the rear axels as I launch. Now that is split across both axels but 31 spline axels seem to be rated at about 7000ftlb so I don't think that gives me much of a mergin. If I stick a blower on it later then then I think it will definately need more than 31 spline and I would rather spend money only once. As for the spool, it is only going to get run on the strip and on a dyno to set it up and at 168" wheel base I don't think an LSD will change the turning circle much.
Am I being overly pesimistic about the rating of the rear end?
What vehicle, what weight, what tyres etc ?
I drove with a spool for a few months, mainly as it was the cheapest route to a 31 spline rear as the diff I had ordered hadnt arrived yet.
Words cannot describe how horrible it was !!!
Motorway etc was fine. But low speed manoeuvres were terrible. Parking, turning. The car was very jumpy, turning circle was increased, it scrubbed the outer edges of front tyres like crazy.
On a handling track at Elvington, I could do nothing but go straight. I ended up through the cones at every turn !! I couldnt believe myself the difference it made.
On the drag strip, it made no difference whatsoever to my cars ability to go forward.
So it depends what you will be using for, and how often it sees the road. But for me, never again will I use one.
I also see a spool for the risks involved. Should one shaft break, what will happen ? All drive to one wheel. To me that spells crash.
I dont know of an LSD that would do the same.
Although on drag style tyres when moving about, the spool doesnt seem to be as much of an issue. The soft tyres take up a lot of the nastyness of the spool.
On road or track tyres, it is truly horrible !!
I use a Ford 8.8", 2.66 1st gear, 3.27 rear ( have used 3.55 in past ) and a Ford Racing Torsen diff. Car approx 1580kgs on MT DR's or similar.
When launching, I have twisted 31 spline Moser shafts, maybe by one spline or so.
I guess it is just luck that they never turned more, as it was by chance I had removed them and found the problem.
Oddly...I never did twist the 28 spline Moser shafts. I'm thinking that is because the shaft itself was thinner, and perhaps took part of the strain by twisting or springing ?
I'm now using Mark Williams 31 spline shafts, and so far no issues there. Although they were about 2-3x the price of the Mosers.
The only LSD option for a 33 spline shaft was a typical plate/locker diff which had a diff pin.
IMO any diff with a pin has a weakness, and I wasnt prepared to use one. The diff and gears may be strong, but Ive seen far too many diff pins fail. Thats why I wanted my Torsen diff.
So while I wanted 33, it was a no go for me. Plus the diff cage would be weaker around the bearing area due to the larger hole through them for the bigger spline.
WRT above, the 9" I assume is bigger all round, so some of those weaknesses might not be a concern.
But I hear what you are saying about wanting the strongest.
