First post on this forum.
Can you answer the following? (also, why don't my posted images show up)
Twin SU Manifold machined
As I now have the Holley I have to find out as to what I must next do to the manifold .
I have attached photo and sketch of manifold and possible machining options. I would be more than grateful for any info you may be able to give me.
As you can see from photo I have cut off original carb mounting block and machined down to manifold flat.
On the sketches Fig 1-2 show how fuel is distributed thro manifold to cylinders before machining. A double plane manifold.
Fig 3 shows if I machine straight thro to expose all, and bolt carb on top Fig 4 shows if I do same but weld plate in middle which would be best and more important which would work.
Am I on the right track or way off ?
I appreciate I may have to weld a block on top of manifold to mount carb.
edited by Coops
