Hotwire question
sowat
Hotwire question
Post by sowat »
Going from 3.5 carb to 3.9 hotwire in my Devon
Mocked up the efi on my old engine in the car for set up
To fit the avaliable space can I turn the airflow meter 90 degrees so the wiring connection is at the top ? or mount it behind the engine up on the bulkhead were I have more room ?
Range Rover throttle cable bracket, this is too wide is a smaller one avaliable ?
JSF55
Post by JSF55 »
Hi Russ, i managed to cut mine down, saved about 3" , still some pics of it here
http://rides.webshots.com/album/5610224 ... e?start=48
So thats where it went !
Re: Hotwire question
sowat wrote:Going from 3.5 carb to 3.9 hotwire in my Devon
Don't think a hotwire unit will be worried about orientation.
sowat
Post by sowat »
Thanks for that
Jon, what throttle cable did you use ?
JSF55
Post by JSF55 »
Push bike brake cable, works every time :wink: just need too get a screw on nipple for the other end from a motorbike shop or VWP
http://www.vehicle-wiring-products.eu/V ... mepage.php
