i have fitted a non standard fuel pressure regulator as my origanal was giving me trouble, new one has a gauge, what presure should the system be at? when running now its at about 20psi, an was about 35 ish when primeing.
its a flapper efi engine, but is running an emerald ECU.
Ralph
Efi Fuel pressure
Re: Efi Fuel pressure
Flapper is 36 psi vacuum disconnected. Drops to about 28 psi at idle with vacuum connected. But the second reading will depend on cam, ignition timing, etc.Ralphh85 wrote:i have fitted a non standard fuel pressure regulator as my origanal was giving me trouble, new one has a gauge, what presure should the system be at? when running now its at about 20psi, an was about 35 ish when primeing.
Ralph
Will Reeve
If you're running a custom ecu then the actual fuel pressure isn't to important. As long as you have enough to fuel pressure for the required power level.
you will need to tell the ecu what the fuel pressure is and also the fuel injector flow rate for it to work out the required fuel.
You can do an easy calculation to estimate your fuel pressure you'll need to reach your expected power. Just Google fuel injector flow calculation.
Is you're new fuel reg a rising rate type? these aren't ideal for custom ecu's. Only really a bodge for standard ecu's to increase the fuel a little.
Tom
Tom
