Right after getting the engine running the otherday it took it for a drive. When i fist started it the oil pressure was just over 40 psi. After driving it about for a while it dropped low to about 12... its a rover so sometimes they do go low dont they ?? ... then it picked back up to 20 .... and then rose a bit more.. i turned it off and let it cool. When i restarted it its started at about 30 psi.
So what could be causing all this fluctuation ??
1) Thge gauge is shot??
2) Engine problems ( its going well though )
3) Leads were round wrong way for a while
and its running a JE injection system, could all the fuel that wasnt burt have gone and mixed with the oil in the sump ... the oil is smelling fuely, Hence the oil will be thinner. Will thin petrolly oill mean less oil pressure ????
Ive got a headache now will loads more problems ive had with it today lol
Any help appreciated
Thanks Slatter
