SU throttle disc play
Will Reeve
Post by Will Reeve »
Is this excessive? Feels OK with a closed throttle and gets worse until open throttle. I see someone has soldered the bypass up! I don't really want a full rebuild kit, just the service kit (fingers crossed!)
http://www.youtube.com/watch?v=NOlSSYQp67g
steveshaw
Post by steveshaw »
Mine have similar ammounts of play and have set up OK on idle speed, mixture and balance.
Still working on hesitation on acceleration, trying to decide if its damper oil weight or ignition issues.
RoverP6B
Post by RoverP6B »
That looks excessive to me and if it were mine I would not be happy with it.
Ron.
4.6 Rover 3500 P6B
Will Reeve
Fixed with the service kit! There are two rubber "springs" at each side of the spindle, mine were disintegrated! New ones fitted and there is no movement! Result!
