coil ?
bones
coil ?
Post by bones »
hi all, ive got a c4 coil on my rover sd1, would the c4 coil be ok with the 347 sbf, :D rich
The engine to which a coil is fitted doesnt matter.
What does matter, is how you fire/trigger the coil.
bones
Post by bones »
will be using a mallory magnetic dizzy, i cant remember the name of it but i think its a hyfire 6al ignition , :D rich
Then you need to know if your coil is compatable with that, not the engine type.....
Cant answer though as to whether it is suitable.
Id guess that if it was a dizzy for electronic ignition then it would probably work.
bones
Post by bones »
ok cheers for the replies, thanks :D rich
Return to “General Chat Area”
