main cap bolt size.1989 3.9
Could anyone tell me what size and what thread type the main bearing cap bolts are?I have a slightly damaged thread in the block and would like to run a tap down it.Thanks Nick
Re: main cap bolt size.1989 3.9
I do not know Nick but if I am not certain I usually turn the bolt 2-3 turns through the die I think is right to check the size.
nickm wrote:Could anyone tell me what size and what thread type the main bearing cap bolts are?I have a slightly damaged thread in the block and would like to run a tap down it.Thanks Nick
Very very few 3.9 engines ran the interim cover.adamnreeves wrote:I think the 3.9 runs the interim cover? If so then yes.
nickm wrote:No.Does westfield supply the bracket?[my engine is an early 3.9].Cheers Nick.
P6 alternator bracket isn't going to work for it either unless you extend it or fit an SD1 front cover and P6 pump.
