I took my Rover V8 powered kit car around Llandow circuit this weekend, and I have a problem with fuel leaking from my Edelbrock 500 carb under heavy braking.
First of all, the top of my carb pokes out of a hole in my bonnet, and is topped with a hilborn scoop. I noticed that under heavy braking, I had a strong smell of petrol, and a oily film would appear on the passenger side windscreen.No other problems though, running fine, and it didn't catch fire.
I think it's coming from the accelerator pump rod, which is near the front of the carb on the passenger side. Would heavy braking cause fuel to slop to the front enough to leak out here? If so, how can I fix it?
One contributing factor might be that my carb is tilted forward slightly. The engine is mounted level and I have not used a carb leveling plate. I figured that the small tilt of the carb is minor compared to normal cornering/accelerating/braking forces, but who knows?
Jeff
