i think the 4.2/4.6 this came off maybe had an oil cooler?? as it has a few take offs which i hope to block up, (ones in the dark blue path).
the oil obviously goes in the red direction through the pump plate, it would be able to freely take the dark blue path, but the direct route which i want to use in light blue seems to i have maybe a pressure release valve in it?? or maybe a 1 way valve? either way i cant blow throw it. then it goes up the green path and in tot he engine.
do i need this pressure release valve? or is it just there to make the flow go throw an oil cooler???
if i block the blue path should i remove what ever the restriction is in light blue path???
Ralph
