Hello all,
sorry if this subject has been covered before but im just about
to bolt the sump and front cover/waterpump on my rover v8 engine,,
i was going to use stainless steel bolts that are on ebay all the time,{with copperslip } but i was told recently that using SS bolts are in fact a 'bad idea' on aluminium ???...and that i should use normall steel bolts? , is stainless a bad idea??........ what do you think ......................
thanks steve
stainless steel bolts on rv8 ??
MGR
No problem with ss into ali.
You can use a silicone spray between the two if you want to just as belts and braces.
We use ss to ali fixings on an almost daily basis in the marine industry and have no problems.
The real problem arrives when you introduce salt water but am guessing you are not likely to be float testing your car
Paul
Paul
Re: stainless steel bolts on rv8 ??
The first Rover workshop manuals dealing with the V8 insisted you use ScotchGuard sealer on any bolt thet went into ally - it seals and locks the thread and prevents corrosion. A litre tin costs about 30 quid and will do many many rebuilds. I still use it, and have never had a bolt shear.mgrv8 wrote:Hello all,
thanks steve
I had a 2 litre Alfa some years back that lost one of the plugs they fit to the cranks when they drill the oil galleries, running a bearing and when I stripped the motor it took a lot of cursing and swearing plus lots of WD40 to remove the head because it had been fitted dry and quietly corroded solid over the years.
I cursed the bugger that built that motor to hell and back, but it was sweet to drive after I fixed it!!
