The connections to the coil is simple enough but just need to confirm what to do with the dizzy.
My dizzy is a electronic Lucas 35 DLM8 with an ignition module mounted on the side, the - green wire and the + violet wire need to connect to the dizzy but do they connect to the ignition module or does it need removing?
Ta
