Piston/valve clearance
Paul V8
Post by Paul V8 »
Hello, does anyone know what sort of clearance I should have between pistons and valves. I'm using a crower 50232 cam in a 4 litre. I have contact and need the pistons pocketing.
I seem to remember that I needed around 70 thou clearance. But I'm probably wrong as usual???
Boosted LS1
Post by Boosted LS1 »
it's the exhaust that's important as it's opening when the piston is on the upstroke. I agree with the above, you need .060" or thereabouts.
Just to add another vote for 60 thou minimum.
jefferybond
Post by jefferybond »
Boosted LS1 wrote:it's the exhaust that's important as it's opening when the piston is on the upstroke. I agree with the above, you need .060" or thereabouts.
Exhaust will begin to open on the downstroke, before BDC and close a short time after TDC.
The intake will be opening just before the piston reaches TDC, and since the intake valve is larger, it might need larger cutouts too.
Jeff
