Dowels for cylinder head/block sizes
Paul V8
Post by Paul V8 »
Hello again.
The new engine I'm building hasn't got any dowels in the block to locate the head, does anyone have the sizes of them so I can have some made.
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Paul
Can you not buy these from Rimmer Bros,RPI os Real Steel?
Sorry but dont have sizes so not a lot of help really.
Paul
bigaldart
Post by bigaldart »
Pretty sure we made some from 1/4" rod. Just measure diameter using a drill bit and a caliper for the depth, leave enough space for air and make sure you have a healthy chamfer.
Alan
ppyvabw
Post by ppyvabw »
Just jam some suitably sized rod in the hole. I believe the dowels from Rimmer Bros that I bought were about 15 quid. Rip off! I see no reason for them to be case hardened as the normal items are.
spend
Post by spend »
bigaldart wrote:Pretty sure we made some from 1/4" rod. Just measure diameter using a drill bit and a caliper for the depth, leave enough space for air and make sure you have a healthy chamfer.
Alan
1/4" is the measurement I have used for gasket cutting patterns (6.36mm for the gasket hole).
ged
Post by ged »
Hi Paul,
Just pop down to your local engineers merchant. Ask for blind hole dowels. They are threaded internally for easy removal & have a small flat on the side to let the air out when you push them in. Shouldn't be more than a quid each.
Regards Ged,
DEVONMAN
Post by DEVONMAN »
Hi Paul.
I needed some quick once and used the blunt end of a drill bit that fitted snug. I then cut the end off with a cutting disc and used the bits as dowels. Can't remember the size though.
Regards Denis
