What is this???
wayneb911
What is this???
Post by wayneb911 »
I need to slim everything down at the front to get the engine in my lotus
Can anyone tell me what this set up is or what my options are.
Image[/img]
Regards
Wayne
topcatcustom
Post by topcatcustom »
Is that your engine? The only way to get the front cover any slimmer is to get rid of the dissy, the one in the pic is slimmer than you would ever get with a belt drive water pump.
TC
wayneb911
Post by wayneb911 »
No thats not my engine. It is in an S1 Esprit but the guy sold it. Trying to find out as much as i can from the old owner. So what sort of system is this at the front as i cannot find any information anywhere. Or has someone made this water pump? Distributor is not the probelm but space when it comes to the water pump as i dont have much room. Space wise is very similar to the setup in the picture so as you can see its very close to the front of the chassis.
Regards
Wayne
Post by CastleMGBV8 »
Wayne,
Is it clearance at the crank pulley that's the problem, the most compact standard solution is to use the P6 or modified SD1 crank damper/pulley in combination with the SD1 front cover and P6 water pump which all lines up.
You will need a P6 alternator cradle.
Dont know what the water pump in the picture is but am sure a lot of people would be interested to find out, not sure if that pump will affect the overall depth of the engine though.
I know of a Rover V8 conversion into your model of esprit, a Pink one! and Dave Vale at V8 conversions knows the car well and can supply some of the parts you will need, give him a ring on 01689 858716
bones
Post by bones »
http://www.britishv8.org/Articles/Short ... r-Pump.htm . do you need it shorter than this :D
wayneb911
Post by wayneb911 »
Thanks i will give Mike a call. Be nice if there is a standard adaptor out there for the gearbox mating!! The water pump pictured will prob do it. So is it easy to modify myself. I take its not a case of just cutting it down?
Regards
Wayne
JJMclure
Post by JJMclure »
looks like an electric pump to me or at least some kind of electric/mechanical hybrid?
topcatcustom
JJMclure wrote:looks like an electric pump to me or at least some kind of electric/mechanical hybrid?
I think its just a blanking plate incorporating the thermostat which relies on an electric water pump.
TC
Return to “Cooling Area”
