I have a Lucas DLB120 coil with a Ballast Resistor on my Mallory Twin points.
I am modding the Mallory with an electronic upgrade.
Should I fit a sports coil like the DLB110?
I believe I need the Ballast resistor but I don't know why?
Regards
1973 MGBGT
1975 MGB V8
I thought I could see the light at the end of the tunnel but it turns out it was a train comming!!
That coil is listed as still being a points coil and the blurb saying it allows you to open the plug gaps. It will probably work for you but I think there are better choices now your going over to electronic ignition.
your probably ok with what you have got,i think it tells you in the ignitor instructions the correct coil rating to use,this is the critical figure,i think it states a max figure of 1.5 ohms but am not sure
