im using the bosch 044 motorsport fuel pump,
should it have a non return valve in the outlet end?
as i have just started to run the fuel lines under the car and have the -6 x m12 adaptor if i remove the banjo fitting to fit this adaptor to run the braided i will loose the so called non return valve that is fitted to the 2.8 capri bosch pumps, (in the banjo fitting housing)
No doubt Stevie T will answer this one
