My newest project is to build a TR7 V8 from a TR7 4 pot banger.
I have a tired 3.5L Rover V8 engine in my garage and access to an even more tired 3.9 L Rover Engine.
I would like to achieve at least 220 - 250 HP at the flywheel.
The 3.5 SD1 engine put out in the region of 155 HP when new and the 3.9 around 180 HP.
I am on a budget
Whilst I think that the lowest risk, cheapest and most sensible option will be to refurbish the 3.9 L engine - decent cam, ported heads, decent headers, dual plane manifold and Holley 390 or Edelbrock Weber 500 which should give me around 230 horses, I like the idea of a "do-it-yourself" stroker motor.
The RPI, Real steel and Rimmers stroker kits are way too expensive for me and beyond my budget.
Is it feasible (probably not sensible) to get a buick 300 crankshaft sent from a USA breakeryard, import a flywheel from D & D, grind the crank main journals and create an instant stroker motor - 4.3 litres if fitted to the 3.5 block and 4.8 litres if fittted to the 3.9 block?
I understand that Hot Rod magazine (USA? UK?) ran an article on this conversion some years ago.
Anyone got a copy, please?
I am in South Africa, and we can get rebuildable cut-out American V8 engines for around 500$USD (full cost, landed in SA).
(Rebuildable means they guarantee that the engine turns and is not trashed, or the vendor will supply a replacement. At best, you can get away with a clean-up, set of rings and bearings. At worst, it is a re-bore, new pistons and reground crank, plus new oil pump.)
I realise that a cheaper route would be a Ford 302 Windsor Ex Mustang (500$, pretty cheap to overhaul), but I like the like Rover / Buick engine, and the thought of a 5.0 Litre 250 HP Rover engine is mouth watering.
An alternative option is to get a 4.6 Litre range Rover engine from a breaker, and transfer front cover etc - but this is much more expensive - around 1,800$ for the engine.
Yet another alternative is to try and get a complete Buick 300 1964 Aluminium cylinder heads breaker engine - then I can use the heads, too (need to reduce the compression ratio and import a fabricated flywheel).
Any advice will be sincerely appreciated.
