When I built my chevy v8 I installed the o-ring type of seal down the valve stem,I know now that was incorrect,do you think this is causing the blue smoke out of my tailpipes? Having had the engine up to normal temperature I can not find any crankcase pressure whatsoever.
Until My finances allow me to buy some performance heads are there any seals that I can fit in the meantime better than these O-ring type?
The heads are 1969 vintage
Cheers Dave
chevy valve seals
Re: chevy valve seals
Hello Dave..... stock rubber seal slid onto valve stems... & not in seal groove ..not doing much good @ all.... Here's a real old trick for cheap posi seals on old SBC heads you have.(if stock guide bosses still in heads)dave350v8 wrote:When I built my chevy v8 I installed the o-ring type of seal down the valve stem,I know now that was incorrect,do you think this is causing the blue smoke out of my tailpipes? Having had the engine up to normal temperature I can not find any crankcase pressure whatsoever.
Cheers Dave
Use GM TRUCK head seals... they are rubber posi seals that fit right over stock valve guide bosses.... they have a small wire band that grips guide boss and they stay put.... & there dirt cheap to by... prox 10 GBP set 16
Cheers! Daryl
Seals
Dave.... ... go for 1978 Chevy 350 engine in Chevy pick up truck... these rubber posi sealed used in almost all Chevy trucks 1/2 ton & 3/4 ton... see if i can dig you up a Sealed Power or Perfect Circle #....cheers! Daryldave350v8 wrote:Thanks Daryl,
Great idea,what Model/year truck seals do I ask for?
Cheers Dave
