so just why are rover v8's so expensive?
Re: so just why are rover v8's so expensive?
They can be expensive if doing extensive modifications for a much higher power output but for a standard rebuild, probably no more expensive than any other similar spec low tech V8 engine.DR JONES wrote:why are bit's so expensive?
What bits are you talking about, as you may be looking in the wrong place.
Rover bits are expensive because they made relativly few of them (the entire output from rover was equivilent to about 3 months output of one of the small block chevy factories).
Also they have the Range rover factor, the assumption by parts supliers and garages is that any one with a range rover is so loaded that you can charge them whatever you like for goods and services and they will pay it. . . most of the rover V8s ended up in ranger rovers. . .
Because its not a 350 chevy.DR JONES wrote:why are bit's so expensive?
Try building one with more than 300bhp then. Standard rebuild they are a relative bargain, mild tune they aren't bad, but start going a bit crazy and you can say goodbye to your wallet.POAH wrote:don't think they are that expensive
You want a race engine that holds together, it's gonna cost 10k, whereas the equivalent power output from a chevy would be half that. But then again, the chevy weighs more etc. There are a lot of factors.
If I had my choice (and money) again, with what I've spent I could have slung a Viper V10 on megasquirt in my MG.
if i ever have the funds to do the cappa again it will be a LS1 v8 going in,
yup,
never mind have to make do with the rover thats going in for now,
Basically we are talking about a 50+ year old design that was intended to have good torque from off idle and peak at around 4800RPM.
Strap on a pair of modern four valve per cylinder, heads on and the power woud start at 70BHP per litre as standard with relatively soft timing and without variable valve timing add that and the sky's the limit depending on the strength of the bottom end.
Now if the Rover M16 heads could be made to fit, no no I must stop thinking of things like that
If one day I win to Euro Millions : http://www.grandprixclassics.com/FactSh ... o%20V8.htm
