Theres no problem withe the TH350, its been about for years.
Back to the original post, Noisy gearbox, Normally once the noise is noticable, tne damage is done, you could try EP90, which is thicker and may quieten the noise and make it drivable. 20/50 seems a strange choice for a gearbox it has no pressure addatives to maintain the oil. thats what the EP stands for, Extra Pressure,
Now heres a question for the MGB owners, why do MGB owners who have converted to V8s have a fixation on using the the R380, They are EXPENSIVE, Hard to find and easily confused with its older brother the LT77, I would be using the LT77, there are plenty of people on this site using LT77s and giving them SERIOUS abuse, the Axle will give out before you break the gearbox, and MGBs have issues with getting plenty of sticky rubber under the arches, so you have a safety valve built into the system to protect the axle and gearbox, Fit a LT77 its cheaper, you wont break it, especially if you have been using a MGB 4 speed, I think the old P5 boxes were based atound the B box, and Nobody will use one of those cos they are fragile.
