Got a P5B at the moment that's refusing to play ball - basically when it's cold it starts up right away, idles well and will run indefinitely, even when hot and driven hard.
The moment you turn it off, it's nigh-on impossible to restart - it doesn't even cough.
I gave the carbs the quick once over, cleaned the dashpots and needles, check the fuel filter and flow (have good flow to the float chambers) and cleaned up all the plugs.
Ignition system looks OK and I have a visible spark - just wondered if maybe it's not strong enough once the engine's hot and trying to restart?
I seem to remember a lot of problems on these with fuel vaporisation but it seems a bit extreme - either that or low compression - but the engine runs very well otherwise.
Any tips or guidance appreciated
Lewis
